Gloom me
- Aug 14, 2008
Anyone using the Logitech G Pro Wireless mouse? Please can help me test out an issue I encountered? Thanks.
Assuming you are right-handed, by default right side keys (G8 & G7) are not in use.
Enable these keys.
Assign a Macro to either G8/G7).
Macro setting: No Repeat > Text and Emojis
Enter 1111 (or 2222 or AAAA, BBBB etc...)
Save.
Ok now fire up Notepad and Google webpage side by side.
Press the G8 or G7 key as set above.
For my case, Notepad has no problem. Whenever I press G8, 1111 automatically typed out.
But on Google website, surely there will be missing '1'. It either came out 1 or 11. Not the 1111 which I set.
By the way, it's not only on Google website, whatever website I go to, pressing G8 will not work as set in macro.
Also tested on Chrome, Firefox, Edge... same issue.
Enable these keys.
Save.
