[Help] LTE - FDD M1 M2M
ZaineJJ
Hello guys,
I would like to know if M1 M2M supports LTE - FDD ?
My company received the Sim cards from M1 and unfortunately the sim cards doesn't receive signals from HuaWei routers bought from China, Xiao Mi tablet from China.
But personal mobile phones is able to receive Signals.
Could anyone which is an expert in this share experience and information about M1's Supported Modulation :s11:
The M2M website
https://www.m1.com.sg/business/mobile/solution/m2m
Thank you in advance!
Tiger9119
Hello guys,
The M2M website
M1 is using LTE band 3 (1800MHz) and Band 7 (2600 MHz).
Check whether the devices support these frequencies or not?
ZaineJJ
From what i googled online the router specification is
https://www.4gltemall.com/blog/tag/huawei-b310as-852/
3G Network Bands 850/900/1900/2100
ps. Router were bought from China 2nd hand
But the thing is i tried with Prepaid cards from M1 the $5 / $15 Prepaid card it was able to get signal and give out data for surfing the web.. Is it possible that it is the Sim Card's specification?
You should check the router’s specification and see if m1 supports.
If you can’t use after a reset of router, likely the router is incompatible.
Thank you for your response, yes i tried turning in on and off, resetting the router and it doesn't work probably the router is not supported.
Tiger9119
Maybe you have to set the M1 APN in the router.
eric3743
Have you test the SIM card if it is working or not by putting in phone to check.
Prepaid cards are already activated once purchased/issued.
ZaineJJ
The router has configured it to sunsurf auto.
Yes, i tested the M2M sim cards on my mobile phone and tested it on router and xiao mi tablet from China, the M2M sim doesn't receive signals from M1..
I tried placing a prepaid M1 card into both china devices it is working also.
:Update
Thanks for your assistance everything, i called M1 about the M2M and they said that the M2M sim cards are provisioned for 3G service, supported radio frequency are 900MHz and 2100MHz. That is why the China tablet and Router isn't working... Guess i solved it with all of your help and will contact M1 to upgrade the plan.
Really appreciate all your help!
