Help me build my Ryzen 2600 computer
NSFnewbie
Please feel free to put any comment on my proposed build:, budget of $1.2k.
Mobo/CPU: Asrock B450 Pro4/Ryzen 2600 -$396
CPU Cooler: CoolerMaster MasterLiquid ML240R -$134
Memory: DDR4 3200 C16 KLEVV Bolt X (Hynix Korea) 16Gb-$195
GPU: GALAX GTX1060 OC 6GB (Black)-$389
The prices quoted are based from Tradepac's pricelist, so most probably will buy from them.
I will use back my SSD (Samsung 860 EVO 500GB) , PSU (Seasonic M12ii 650w) and Casing (Coolermaster CM690 II) to minimize the spending.
Will overclock the CPU to 4.2Ghz. And will use it for some gaming and 3D Rendering and Animation.
singupingu
No problem for everything, except the 4.2ghz oc, which is dependent on your silicon lottery :D
Sent from OnePlus ONEPLUS A3003 using GAGT
Hailgod
130$ cooler on a ryzen 5? hyper 212 good enough
Sent from Xiaomi REDMI NOTE 5 using GAGT
Kousoku
Go for the 2600X and get a good Air Cooler instead. For the 2600 non x, unless you tio silicon lottery, if not even 4.1 Ghz under 1.4V will be hard to achieve if you are unlucky. At least for 2600x you are guarantee to get up to 4.2Ghz single core, 3.9ghz all cores, maybe even higher with PBO enabled, provided you have enough cooling for XFX & PBO to do it's job. I've a friend with the 2600 who cannot reach 4.1Ghz OC all cores without pushing his core voltage up to 1.425v & abv, but then again it's all about luck.
NSFnewbie
Thanks, will consider this.
xboxer
Is buying a brand new 1060 still a smart choice?
I mean the 2060 should be coming soon.
But the prices of the new RTX have been jacked up so much.
kennethoka
ryzen needs dual channel. your board has 4 ram slots. just get 2x 8gb.
Can you direct me where to find this information? I really cannot find info on this.
All I found in youtube is showing ryzen is able to run on single dimm and for gaming purpose, the difference between single and dual is no much.
Ferolare
https://www.reddit.com/r/Amd/commen...ryzen_performed_in_a/?st=j1s1tx1x&sh=54516f49
https://imgur.com/a/Awm6O
can ignore the 2133 set of results - DC does give a performance uplift (but only in the 0.1% frametime)
*assuming you're playing at not-1280x720 resolution
Hailgod
dual channel has significant improvement for ryzen systems. no reason to waste that power by limiting yourself on a single channel
