help me choose!! 2.0 speakers
zhihao57
Hey guys, currently i'm in dilemma which 2.0 speaker to choose from.
EDIFIER R2000DB $240
MackieCR5BT? / Mackie cr4BT? $351
Presonus E4.5? $265
Which do you guys recommend? Personally have tired edifier and mackie alr, havent get the chance to try presonus. Any suggestion for people who have xperiences with these speaker?
5star_pundit
Presonus E4.5? $265
My 2.0 edifier setup
PC --> optical cable --> edifier S1000db --> HD600
________________________________________________________________________________________
Processor
AMD Ryzen 1700X | EK-Supremacy EVO
Mainboard
MSI B350 Tomahawk Arctic
Graphics Card
MSI GTX1080 Gaming X | EK-FC1080 GTX TF6
Memory
Adata XPG Spectrix D40 2400mhz 2x8gb
Display
Acer XB271HU
Storage
WD Black NVMe 512Gb SSD
Casing
Be Quiet Dark Base Pro 900
PSU
Enermax Platimax DF Platinum 1200w
Audio
Edifier S1000db | Sound Blasterx AE-5 | Sennheiser HD600
OS
Windows 10​
lucied
Suspended
The r2000db has dynamic mode switched on by default and you have to change it to classic every time you power it on. Might be good if you like your music v shaped.
Great speakers for ~$230. Used for 5 months or so.
meandyou
Presonus E4.5? $265
Would you consider S2000 Pro, IF top up additional.. say $100+-?
Or
Wait for upcoming IT Show, R2000DB could save you about $50+-?
:o:o
xuan87
I listened to the Presonus E3.5 last weekened and was blown away by the sound quality that I heard from that price and size. I think you own it to yourself to listen to the 4.5 before you decide.
zhihao57
Thanks for the feedback!
A little background info. I currently own a Mackie CR3, am gonna buy another set of 2.0 for another desk setup. So its not really a replacement/upgrade!
Tried z623, too bassy for my liking, kinda annoying, Voice and everything not clear as compared to my mackie cr3, maybe i used to cr3 alr. haha!
I don't need these speaker for work or anything, just casual gaming, listening to music
Wah!! Any idea where can i find a place to test it?
Or
:o:o
S2000Pro would definitely sound better, but right.. the color doesn't fit my desk setup :( so its definitely a nono! HAHA Is there a
Save $50? means around $180-200 for R2000DB, tempting sia! I'm waiting for IT Show to buy my monitor, so might actually one shot hoot all if i decided on R2000DB.
Which of them do you like and what do you hope can be better?
I wouldn't say i'm very good and listening to audio and stuff.. but base on my opinion, my current Mackie CR3 is kinda lacking in the bass area. Edifier R2000DB does actually sound much more bass if i were to compare it to cr3. I have not tried CR5.
I'm very attracted to Mackie's design tho..(Except for the green rings, which i most probably will paint it white/black or smth..)
The volume knob is at the front which is really a plus point.
Edifier, cheap and good quality base on what i hear from this forum. However volume knob is at the back.. zz
Presonus Eris e4.5, Never test it before, great design tho..
Where did you get your R2000DB? Cheapest i could find is $240 on carousel :/.
xuan87
You can listen to the Presonus at Sinamex at Parklane mall, check their opening hours before going down.
The Mackie CR3 is a pair of monitoring speakers, which means they tend to be quite flat in sound and bass light, that's how monitoring speakers are meant to be. Presonus are monitoring speakers too so you'll likely love how they sound.
If you want more bass, what you can do is choose a pair of monitoring speakers that allow you to hook up a sub to it for more bass. But few have this functions, off the top of my head, only Kanto speakers and PSB PS1 Alpha.
zhihao57
Ahh! The edifier is also studio monitor right? Haha
As for a subwoofer out, edifier r1850db has it, it's slightly smaller compared to r2000db
But would it be fine if I just plug into my com's subwoofer outlet?
xuan87
yea it should be fine. but note that I have not ever done that, just that in theory there's no reason why it shouldn't be fine.
