GarnetDragon
- May 13, 2021
when you'd buy lappy or desktop?
my lappy like dying after 5 years..
looking at those minipc(some sort like macmini but windows version )
or maybe built an mini-itx desktop..
application : mostly edmw + there is a slight chance that I may play diablo4.
1) what do you all think ah?
2) what's the idle watt for desktop ?
3) minipc can be had for like $800
looking at maybe 16gb x 2
at least 1TB SSD
if GPU maybe 3050
Diablo 4 even use rtx 3080ti also lag
Suggest chiu top up abit hoot a rtx 4090 system![]()
What is more impt to you? Power savings, portability or upgrade options?
If going for Power savings and light gaming, get Mini PC with AMD RDNA 3 IGPU.
If you want to upgrade every couple of years, get a normal pc.
If you want portability and power savings, get a laptop.
Not out but shld be soon.Mini PC with AMD RDNA 3 IGPU. <= this one out le meh? If so, can I have the link(s) pls? Thanks
Handhelds with the chip will also be out soon.
I follow this channel to see him test it when it's out.
https://youtube.com/@ETAPRIME
Dam I was lateYou Heypi Can liao
also the idle is like 50w rite?mini pc will do the job
itx not cheap to build also. am now using a itx abit regret
you can use @YouHappyCanLiaoDam I was late
In after
" You heypi can liao "
