Help me decided between this 2 build
dEaTh1sCoMin
Is there any con and pro between this 2 build
Msi h97 pc mate
I5 4460
8gb ram
1tb hdd
240gb ssd
Gtx 970(leadtek)
Sharkoon t28
Thermaltake smart se 530w modular
Price 1490 *come with free OS
OR
Msi z170a slait
I5 6500
8gb kit hyperx
1tb hdd
128gb samsung evo 850 pro
Thermaltake smart se 730w
Gtx 970 asus turbo
Corsair air 540
Prices 1860*come with free OS
Price are offer by my gamer friend friends
Or what can I go for with my budget of 1.4k-1-8k max(the lesser the merrier)
GTX 970
SSD 240GB
HDD 1TB
No need monitor,optical drive,wifi adapter,keyboard and mouse
And I don't overclock
Prefer to buy thu shops at Simlim
Thanks a lot for ur time and help
Cheers :)
yusoffb01
U don't need friends who scam each other. Break up with them
That PSU is shitty and cheap, yet they charge u so much. Cheaper to select parts and ask shop assemble
kaixax555
For the first one I got an estimate of 1415 with OS, 1791 for the second one
Quite a big price gap, not an optimal build either. Power supply is crappy too, at least should go for a Seasonic...
i5-6400 + MSI B150M Bazooka @419
1x8GB Kingston DDR4-2133 @84
WD Blue 1TB @77
Crucial BX100 @129
Zotac GTX970 @479
Seasonic M12-II 520W @95
Corsair 100R @89
Windows 8.1 Home 64 bit @135
Total 1507
This is if I follow your requirements and opt for a Skylake system, which means latest processor, and easier future upgrade since DDR4 memory is getting common
However, we can go for this as well
i5-4460 + Asrock H81M HDS @333
1x8GB Kingston DDR3-1600 @61
Crucial BX100 @129
WD Blue 1TB @72
Sapphire R9 Fury Tri-X @819
Seasonic M12-II 620W @115
Corsair 100R @89
Total 1758
While the processor is last gen it is pretty much still relevant today in gaming. With the current budget you can actually get a R9 Fury, which slots in between the GTX980 and GTX980Ti/Fury X in terms of power. May be a little overkill for 1080p but if you upgrade to a 1440p screen it will still rock most games
Sent from outer space using GAGT
herman1314
Thermaltake smart se quality not good? Whats the problem with it? I'm using one myself so i curious and all the online opinions are either: decent, like corsair CX quality, not good or mistake for smart and smart M so i really dunno who to believe:s11:
dEaTh1sCoMin
WD Blue 1TB @77
Crucial BX100 @129
Zotac GTX970 @479
Corsair 100R @89
Total 1507
Crucial BX100 @129
WD Blue 1TB @72
Corsair 100R @89
Total 1758
Bro
The 1st build u suggested
I can play most of the game nowadays at max setting right
