[Help] Micro ATX build for light gaming
fitzz82
Im looking to build a desktop (small size, preferably micro atx) work and some light gaming (L4d2, csgo). My budget is around $800nego, for the system itself.
i checked other threads and couldn't find much ppl using mATX build)
Pls advise what i should go for. Thanks!
case :
pu :
mb :
ram :
psu :
gpu :
hdd :
ssd :
singupingu
CASE: Tecware F3 ($49)
MB+CPU: ASUS H110M-A M.2 + Pentium G4560 ($194)
RAM: Kingston DDR4 8GB ($85)
PSU: FSP Hexa+ 450W ($58)
SSD: PNY CS1311 or OCZ TL100 240GB ($119)
HDD: WD Blue 1TB ($72)
GPU: Palit Dual GTX 1050 TI 4GB ($193.5 after 10% off via lazada)
OS: Windows 10 Carousell ($20)
Total $790.50 +/-
Price quoted from PC theme or otherwise stated.
Sent from Overpowered Phone Mark III using GAGT
singupingu
It's basically the same specs. Higher price as itx stuff are lesser and generally more expensive. Hence, more expensive overall cost for the same thing. Light gaming is confirm can but also see what kind of title you planning to play. You can go YouTube see how Pentium G4560 and gtx 1050 ti perform in gaming. It's not bad to be honest, though not the best value but we are all bound by budget at the end of the day.
fitzz82
Thanks for your help!
if i go for itx, i hav to change to itx casing and MB n cpu ? The rest can remain the same?
i can stretch my budget to 1k
CASE:
MB+CPU:
removed HDD as i already hav a spare.
stylechap
Why don't you search for a case that you like first?
Small for others doesn't mean it will be small enough for you.
I'll recommend you stick to matx as there is additional pcie slot in case you wanted to add in wifi etc.
Jonsbo make some casing that can mount itx/matx board. Maybe you can start from them.
lifeishard
CASE:
MB+CPU:
PSU needs to change to SFX type unless you using m-atx case for itx mobo.
singupingu
CASE: Fractal Design Node 202 ($129)
MB+CPU: MSI H110i Pro AC + Pentium G4560 ($211)
PSU: FSP SFX 450W Bronze ($99)
SSD: 240GB PNY or OCZ ($119)
GPU: Sapphire Nitro+ RX 480 4GB ($308 via LAZADA before discount)
Total $971 +/- without factoring discount.
fitzz82
Thanks singupingu for the input! ithorlick gav mi some ideas too.
Basically i consolidated the info and chose below,
Case: Silverstone SG05BB-LITE - $60+ (cheaper)
MBO: MSI H110i PRO-AC
CPU: Pentium G4560 (better valued den Intel i3-6100 3.7Ghz)
RAM Kingston DDR4 2133 CL15 8GB Single - $85
PSU Seasonic 520W M12-II-520 (chose it cos cheaper and more watt) - $90
im undecided for the GPU. ZOTAC GTX1050 2GB or Sapphire Nitro+ RX 480 4GB
which is a better value GPU?
Thanks for the input!
yamakazi51
The $20 Windows 10 key in carousell is safe or not? Afraid those are volume license that may be deactivated in future
ZrE0_Cha0s
Thank you! Just wondering whether you have any upgrade options for the mobo/processor?
Will have to do some video editing work
can consider getting ryzen 1700/1800 if u are not OC. and for the mobo can consider x370 or b350 (depends on how much budget u willing to put for the upgrades. :o
next is the casing you using also need to consider the type of board u should be getting to fit.
fitzz82
Is it worth to go for ssd m2 PCIe
Hmm.. does e mobo supports ssd m2 PCIe?
shadow84
I can support pcie m.2 ssd although its capped at gen2 x4 speeds. Current max speed is gen3 x4.
If you have the $$, can go for it although u wun really see the diff.
