HELP! mini ITX build
jamesomnipotent
Suspended
i m looking to move from atx to itx case (CORSAIR GRAPHITE 380T) but i realize my current power supply wont fit in...
GPU: GGB R9 280x windforce
RAM: Corsair Vengeance 4gb x2
CPUcooler: STOCK intel i5
SSD : samsung
HDD
PSU: Coolermaster Silent Pro M2 720W (W*L*H 150 x 180 x 86mm)
so..
As i have never built any pc nor have strong knowledge of building one
i need opinions from the guru ..
1. suggested power supply for the case
2. itx mobo
3. case (about $210)
My budget is $500 (good value and good quality)
All opinions and help will be much appreciated. :)
t258jgn
Silverstone SST-ST65F-G 650W Full Modular 80+ Gold
can fit into the case perfectly
jamesomnipotent
Suspended
yes mib500 but problem it seems like i need to get new
1. itx mobo or mini atx mobo
2. psu ( and i m not sure how many watt)
i wan to save as much cost as possible..
MoneyFace =p
You never state which gen Core i5 is that. Different gen using different socket.
How about Corsair Obsidian 250D?
mib500
for psu, 550w with (gold or Silver) sufficient already.. but let said you plan to change greater gpu in the future , you need more watt so 650 should be nice... in the end its up to you... just my 2 cent...
t258jgn
Asus Z97I-PLUS Z97 Skt1150 Mini-ITX Motherboard with WiFi a/b/g/n/ac & Bluetooth
or
Gigabyte GA-H97N-WIFI H97 Skt1150 Mini-ITX Motherboard with WiFi a/b/g/n/ac & Bluetooth
