[Help] mobo or psu issue?
Peach Tea
Suspended
Recently my pc keep restarting. No bsod or after restart dun have message says windows shut down unexpectedly.
PC coming to 2 yrs. What is the issue?
TIA
ZrE0_Cha0s
Can u check your system logs to see what's the error msg they give to u?
voltech
May I ask, at which part of the restart did it occur? Did it restart while its loading with the Windows logo on or at the desktop inside?
voltech
Both also reboot ramdonly :(
It would be hard for you to view the event log as the system will restart randomly. Are you using Win 10 or Win 7? If you are using Win 7, see if you can boot to Safe Mode. How to? After the brand logo splash, spam the F8 key and select Safe Mode.
Peach Tea
Suspended
Yes. W7. Tonight will try
yusoffb01
TIA
i suspect psu
Other things can do:
1) clean ram
2) resit ram
3) reinstall windows
4) remove graphics card
5) change psu
6) replace motherboard
7) replace cpu
8) replace RAM
Doing one of the above should solve your issue
