Hi all,
It's been 6 years since the last time I'd posted and set up a rig. Hence I'm a bit rusty. Need your opinion.
My current rig (specs on right) has died. Powered on, fan spinning, no POST, and neither monitors (dual-monitor) do not wake up from standby.
I'll will probably keep my casing, my HDs (win7x64) and my PSU?
I've been shortlisting the following:
-i7-4770k. I'm thinking of i7 over i5 because I do a lot of virtualization work. Or is there a better CPU in the sweet-spot?
Gen 5 seems to be overpriced now?
- CPU Cooler/fan. Can i make use of the stock, or is there one to recommend? Prefer quiet ones...
-MSI GTX 970. I game BF4, WoT, WoW, WoP. Which would be the better/recommended/preferred brand? I have a dual monitor set up.
-16 or 32 GB Ram. Corsair?
- Mobo. This is the biggest headache, which lead me to posting this. I was doing research reading through the various recommendations... And I was also trying to find my own...but I found it almost impossible to shortlist any mobos.... Each brand has so many different models.... and there's no possible way to do advance filtering/searching of features.. Could you help me to shortlist a few brands.models? I'm looking at built in audio, 2 GE ports if possible, min 6x USB2/3, min 5x HDs/SSDs
- Casing. Thinking of reusing.
- PSU. Thinking of reusing. Is my current PSU sufficient? If not what would you recommend?
I'm thinking this would not break 1.5k ... What do you think?
Which would be the better shop to walk in, pick and assemble for me? PM me if you need to...
Hope you can point me in the right direction... Many thanks in advance.
Cheers,
Cheers,
'Tiong' meaning.. ?
