help: moisture detected
binary_0011
hi guys, my s8 got this error. google liao, tried those methods. still wont go away. what else can i try?
TIA.
binary_0011
no, just taking video in the thunderstorm just now. anyway, it went away few mins after i posted this. will monitor.
twosix
i've experienced this recently. the usb port is wet. dry it by shaking off excess water and let it dry naturally or use dryer in cool mode to fast dry.
cstanhwz
Use a tissue paper, roll one corner into a tip and insert to the USB C port as well as the headphone socket. Twist the tissue paper in the headphone socket. In the USB C socket, try to use the tip to wipe the both sides of the port. Should get rid of most of the water.
Sidler
Just wait for it to dry.
Don't blow. The water resistant membrane can only take certain pressure. Blowing may push the water through the membrane.
