Help moving to mini ITX
mUdpOolEr
Hey guys,
I'm planning to downsize my desktop to a mini ITX and would need some help here with the gfx and casing
GFX
- CPU i'm getting - Intel i5 4440 / 4670k
- Current GFX - ATI HD5850 1GB
- Usage - mainly Photoshop and slight gaming
Qns: The Intel onboard or the 5850 will perform better for my needs? As I can't seem to find a direct comparison online.
Casing
- Need recommendation on casings
- Able to hold at least 1x SSD and 3x 3.5" HDD
- Able to hold ATX PSU
- Able to a decent GFX
- Front USB3 ports
- Able to hit cosair watercooling kit (BONUS - not yet decided on getting watercooling)
Thanks in advance!
hengheng220
If gaming wise, I think 5850 is better than intel hd4600, but why is your vram 512 only? online i check only got 1gb version de leh...
escksu
of course 5850 faster than intel HD. For photoshop, you using CPU so gfx card doesn't matter. Not sure if 5850 supports openCL though.
mUdpOolEr
I'm setting the photoshop to use the gfx, thats y the question.
DeenzX
bitfenix prodigy m best la.. mitx and very good looking.. very functional too.
mUdpOolEr
Have been reading up.
Currently considering between this 3 casings
- Coolermaster Elite 130
- Fractal Node 304
- Jonsbo V6
Any comments on this 3?
Op_Valkyrie
- Fractal Node 304
- Jonsbo V6
You got budget for caselabs? Get S3. Won't regret... Mine is coming soon... :D
royfrosty
Should take a look at obsidian 250D.
Of that 3 you have seen i will choose the cm elite 130
