When you mentioned that it is too hot, what is the temp and why do you think it is a problem?
I am asking the questions because it is not uncommon for slim laptops to run hot. I don't know which HP Probook model you are using but I assume if it is purchased in the last year or so, then it should be pretty slim.
You can attempt to replace the stock thermal paste
Get a laptop cooler.
Lower down the CPU max power to like maybe 50%
Sure thing. I'll put down the specs later for my comp, and temp on diff occasions.
I was just asking a general question so as to know what causes laptop to be this hot. That's the problem: it really is quite hot around the fan area (idk the technical terms, noob here). Feels as if my hand is gonna get burnt or sth if I leave my hand around that area.
I went to HP Support for A/S, and the serviceman said something about HP Probook models are usually hot like this (as what you said about thin laptops), and he mentioned about the material. He said something about heat conduction is good so that it will lose heat faster or sth.
Just trying to find ways that can cool my computer down that won't be so costly because I don't think my laptop will live long like this. Lol.
Searching online kinda helped me in some ways. Tbh I think laptop coolers are great and I've been using one, so if you see my recent post, I posted a thread on promos to getting cooler (and earpiece coz I lyk moozik).
Hope this thread gave you a rough idea about why I asked for help. Thanks for asking!![]()
Hi,
I bought my hp ProBook recently with RAM 16GB and i7 8th Gen, but realised that my laptop gets too hot when I run games or play videos.
Any way that I can reduce its heating effect? Thanks.![]()
Got one laptop cooler that is decent. Nice but a bit big only. Trying to find btr one coz I have an old laptop that suits the size more. I'll put down the product details ltr...
How to lower down the CPU max power? What are some downsides as I lower it down?
Hi,
No worries. I asked those questions because I feel that it may not be a big problem. Because the laptops are thin and in some cases, comes with a metal chassis, it will surely run hot, especially at the vent area. Because that is where the heatsink is, and the area will heat up quite a lot.
As long as it is not giving you any issues like freezing screen, etc, it should not be a problem.
