Help my rig died on me
starpetshub
Hi all my mobo and ram died on me. Should I get the Aftershock rig or custom fit another rig ?
DJ Pork Chop
when u ask for recommendations, it would be good if u state your expectation.
u need to play games? normal surfing? etc?
u want to look at fixing your rig? etc?
starpetshub
Hi oh sure thanks for the prompt reply it's for normal surfing etc with very light gaming.
AFTERSHOCK RAPID GTX 1650 PACKAGE-$799
Rapid Stealth Black Tempered Glass Chassis (Nexus M)
Intel i5 9400F Processor
ZOTAC GEFORCE GTX 1650 SUPER 4GB GDDR6 *NEW 35% MORE PERFORMANCE THAN 1650 NON SUPER!!
ASROCK H310 Motherboard
8GB DDR 2666mhz Memory
512GB NVME SSD
INTEL STOCK COOLING
500W FSP/EVGA PSU 80+ Certified
3 Years Warranty (First Year Onsite)
yusoffb01
512GB NVME SSD
INTEL STOCK COOLING
good spec, affordable with warranty 👍
Glariel
512GB NVME SSD
INTEL STOCK COOLING
jin tok kong
better than mine
Rashkae
512GB NVME SSD
INTEL STOCK COOLING
Be aware:
1. You'll want dual channel RAM 2X8GB not only a single 8gb stick
2. Intel stock cooler CMI and is loud
Rashkae
The Zotac has no fan off capability and gets loud under load. That's why it's cheap.
starpetshub
Hihi so you mean 2x 4gb ram ? From what I know you can't customise those ready to ship rig from Aftershock ? If Intel is bad which would be a wiser choice? AMD ? Ryzen?
DJ Pork Chop
a few things you might want to note:
1. If you are worried about fan sound, can give them a call to check if they have this exact product at their showroom, go there and see if its at a level that affect you
2. Can ask them through phone if its 2x4gb or 1x8gb. 1x8gb is fine. u can buy a separate 8gb stick to put in at a later time if u need. But if its 2x4gb and the mobo only has 2 slot (which i checked, h310 asrock only has 2 slots), might be limiting.
3. The price of the package seems to be worth it, with consolidated warranty for all the parts. But one thing to note is that the Windows is Unactivated
Address:
AFTERSHOCK Hotline: 62930296
AFTERSHOCK SHOWROOM @ B-Central,
996 Bendemeer Road #03-06 S339944
Opening Hours:
Mon - Fri: 11:30AM - 8:00PM
Sat: 12:00PM- 6:00PM
Closed on Sundays & Public Holidays
starpetshub
Address:
Opening Hours:
Hihi so in your opinion you still think this is worth it should I diy another new custom rig getting parts from sls instead ?
_DeS__
State your budget also so we can advise better.
If below 1k just buy at AS , doubt u can get something better in SLS
DJ Pork Chop
imho its pretty worth it for its price. but what will you do with your current rig?
if its ur mobo/ram issue, getting a new mobo+ram, u probably can reuse the rest of your parts. do you want to look into repairing your rig? if yes could you post the parts and let us see?
starpetshub
should e be this specs
INTEL CORE I5-4570
MSI B85M-G43
ZOTAC GTX750TI 2GB
RAM-DDR3
ETC...
6 YEAR PLUS RIG ?
DJ Pork Chop
INTEL CORE I5-4570
MSI B85M-G43
ZOTAC GTX750TI 2GB
RAM-DDR3
ETC...
6 YEAR PLUS RIG ?
zotac 750? lol during 700 series i heard zotac had alot of issues. ur one can last 6 yr is gan power.
Option 1:
u alr have a hdd/ssd/psu/case.
so in this case u can just look at buying mobo+CPU+ram,
and can squeeze in a gpu upgrade if u want.
based on bizgram pricelist @
https://www.hardwarezone.com.sg/priceLists/download/680223
Asrock H310CM-HDV/M.2 - $94
Intel Core i5-9400F - $225
Kingston 8GB - $65
Zotac GTX 1650 Super(Optional) - $235
Option 2:Assuming Motherboard is spoilt
Aliexpress usually sell a lot of used mobo, can take a look.
Search List: https://www.aliexpress.com/wholesal...20200227202817&SearchText=LGA1150+motherboard
ASUS B85M-G LGA 1150 used Motherboard M-ATX B85M-G Systemboard B85M DDR3 For Intel B85 32GB Desktop Mainboard USB3.0 SATA3:
https://www.aliexpress.com/item/329...earchweb0_0,searchweb201602_,searchweb201603_
I found one of them is alot of people ordered + review more than 4.5 star. the motherboard supports your cpu as well.
https://www.asus.com/sg/Motherboards/B85MG/HelpDesk_CPU/
Option 3:Assuming Ram is spoilt
1x Kingston DDR3L 8GB Ram - $65
this route is only if you are willing to spend the time to clearly determine if your motherboard or your ram is spoilt. then followed by the effort needed to DIY.
if it seems like it is too much work, its better to just get the aftershock built pc and buy a cheap windows license.
your old rig just transfer ur hdd/ssd over then the rest of the part sell on carousell etc
