d4rkst4r123
- Aug 7, 2012
Mount rad on the rear exhaust fan
If ur using only a single 120...might as well get aio...unless ur planning wc other components. ..then get a open loop setup..
120mm or even thin 240mm would not be enough if you want to really overclock
Not everybody into oc ma...some like myself wc juz for the sake of wcing etc...I run 3 480s but only wcing cpu mb 2 gpu...overkill of cos but juz for the fun of it...no oc..
