nuker22110
- Jul 11, 2010
Hello, I am currently having a little problem trying to diagnose a problem i am having with my computer. While running high load games like Ark survival evolved, there is a flicker in the screen, approximately once every 5 minutes. In addition, there would be an intermittent black screen which goes away very fast.
I suspected the GPU might be faulty and ran the furmark gpu stress test. The test completed successfully without any screen flickering or black screen. Hence im stumped. In theory if the gpu is failing, doing the stress test would cause the same symptoms to appear, or for the stress test to crash/fail.
Hence, would anyone mind giving any insight into what may be causing the problem?
