Help needed for basic network set up
Apex
Which mean if ax73 is in the DB cabinet, there will have 1 network, and if I go deeper into the house, I will have to connect to another network - AP (CT8) to have a better connectivity?
What i trying to say if
if you get AX73 from M1 now. You still can install a Asus Mesh in future. Just need to configure the future mesh (can be any brand) as aP mode will do.
BTW
Henry Ng
Understand that this topic has been discussed plenty of time, but after going through those threads, I still do not understand.
Just done with renovation and is ready to move in. I am planning to use lan cable in bedroom 3 for desktop and living room for smart TV.
The rest of the house to be filled with WiFi.
Plan to sign up the 1gb M1 package without the routers.
Current fibre/data point is in the DB cabinet next to the main door.
Attached picture is my floor plan and orange circle is where I would like to have my lan cable connected.
Any pros can advise on what routers/mesh model or any other things to get?
No looking at god speed, just sufficient to play movies, surf the Internet, YouTube etc.
Thankyou alot!
The routers are not at the best location.
