Help needed for motherboard battery
simple_n_eazi
Hi
I think my motherboard battery has gone flat. My clock setting cannot be saved and have to changed everytime I on my pc.
My motherboard is Dell 0N826N. Anyone knows what is the battery that this motherboard use? Is it CR2032?
Thanks!
VinceGan
Hi
Thanks!
It's normally CR2032. If you are not sure, the battery model will be indicated on your existing battery.
evq
Just bring the current battery down to the shop
yusoffb01
Value dollar / ABC shops sel for $1.80 for a few pieces. CR2032
If shop dont have CR2025 also works
kaixax555
Should CR2032
i think it is kind of a standard for most mobos already :o
herman1314
it should be cr2032. all of my 5 motherboards from lga 775 to lga 1150 are using cr2032 so i think its a standard
jtjt00
Just leave the mains on after shutdown your desktop, the 5V rail is still on and will maintenance the BIOS settings and clock till you buy the battery.
