Help Needed from expert for my 2TB WD harddisk
davidchi2001
When i plug into the USB there a indication sound the drive is in. However when i go to my computer, the drive doesnt appear. Go to device manager however it is there and I can click safely to remove it.
jtjt00
Is your WD 2TB usb drive previously working and now this issue appear?
jtjt00
Suspect your drive partition table is corrupted, causing it to show as raw.
Google for free utility to fix the issue. This can result from improper removal from USB port while file is opened.
