[Help needed] Hardware components for my gaming rig
royfrosty
Dota 2 do not even need an i7 nor i5 nor i3. They can run well on even a pentium G3220
Dota 2 dont even need till 32gb nor 16gb of rams. Just either 4 or 8gb
Just a regular b85 board is needed with perhaps a little bit invest more with a killer LAN network port.
And a entry level gpu such as r7 260X will do the job.
In total you would probably need about $800 for the entire rig excluding monitor and OS.
Please state what are the things you need,
OS win7 or 8.1
Wifi?
Keyboard and mouse?
Monitor?
Speakers?
Please let us know so we can assist you further.
Hi, thanks very much for your help. But i have a i7 laptop, with Nvdia 540M graphics, but it can only be on normal performance on it, with some lag.
For the desktop, what is the best processor, graphics and MB i should go without overclocking but with cooling system to make sure i dont spend what i do not need for the overclocking?
Lets say perhaps i might be going for other games in the near future. But also with the requirement to run with maximum performance and frame on Dota 2.
I would like to ask :
OS win 7 or 8 would be more suitable for gaming?
Yes with wifi for internet.
Keyboard will be getting razer or something. Mouse currently razer imperator 4G.
Monitor should be roughly 23~27 inch with HD graphics for gaming.
LED/LCD which is better?
Speakers yes, have not considered
royfrosty
That is because you are using a laptop. A desktop performance will pawn a lappy performance due to the difference of laptops power limitations.
In gaming the most important factor is gpu. 540M is a entry card for a laptop.
Not sure if there is such thing as a gt540 for desktop. But if there is, the 2 performance is wide apart.
Thats just some explainations.
So lets say you intend to play other games in future. Not just dota2.
Msi b85 g43 gaming + i5-4570 ~ $384
Gskills ripjaws 1600mhz 2x4gb kit ~ $113
WD blue 1tb ~ $75
Crucial m500 240gb ~ $189(local) $155(amazon)
Powercolor r9 280x 3gb ~ $425
Seasonic g550 550w 80+ gold semi modular psu ~ $105
Sharkoon BD28 ~ $77
Samsung ODD ~ $21
Windows 7 home premium 64bit OEM ~ $110
TPLink WDN3200 N600 dual band USB wireless adapter ~ $45
Swans m10 2.1 speakers ~ $129
Dell s2340L 23inch eIPS panel ~ $219
Total ~ $1897. Buy at tradepac. Diy
If it is purely just dota 2
Asrock h81m dgs + G3220 ~ $148
Crucial 8gb 1600mhz ~ $89
WD blue 1tb ~ $75
Crucial m500 120gb ~ $115
Zotac gtx750ti 2gb ~ $208
Corsair obsidian 350D ~ $139
Samsung ODD ~ $21
Windows 7 home premium 64bit oem ~ $110
TPLink WDN 3200 N600 dual band USB wireless adapter ~ $45
Total ~ $1403. Buy at tradepac. Diy
The rest of the budget will be on the mechanical keyboard that you like most.
Jian19
With future gaming in mind.
$2k
i5-4570 + Asrock b85 killer ~ $357
Crucial 8gb ddr3 ~ $90
Plextor m5s 128gb ssd ~ $118
Wd blue 1tb ~ $74
Msi 280x gaming ~ $470
Seasonic g550 ~ $108
Samsung oem drive ~ $21
Fractal design arc midi r2 ~ $130
Win7 64 oem ~ $115
Dell u2414h ~ $375
TP-Link WN851N 300Mbps Wireless N PCI Adapter ~ $45
$1903 , left $100 for your keyboard. Desktop diff from laptop u no need cooling if u not overclocking. Stock fan is more then enough . Buy and DIY @ tradepac ask for discount. If not sure how to DIY can bring to gs shop ask him help u assemble @ a fee
Msi b85 g43 gaming + i5-4570 ~ $384 Would MSI be a better choice than Asus MB?
Gskills ripjaws 1600mhz 2x4gb kit ~ $113 This would be the best RAM of this price?
WD blue 1tb ~ $75 This would be the harddrive of this price?
Crucial m500 240gb ~ $189(local) $155(amazon)Is this a recommended and good SSD?
Powercolor r9 280x 3gb ~ $425For graphics is Asus or MSI better ?
Seasonic g550 550w 80+ gold semi modular psu ~ $105Can i get coolermaster instead? It seems like a better brand.
Sharkoon BD28 ~ $77Sorry whats this?
Samsung ODD ~ $21Sorry whats this?
$2k
Wd blue 1tb ~ $74
Win7 64 oem ~ $115
Dell u2414h ~ $375
Wow thanks alot! i am considering between both recommendations. But i would be prefering for graphic and MB for Asus or MSI , the more well known brands, seems more reliable. And for the cooler, seems like Coolermaster is good.
royfrosty
1) mobo among all the 4 brands locally sold such as Asus msi asrock and gigabyte are trusted. Nowadays mobo is more of a heng or suay thing which is gonna spoil sooner or later. There are people whom buy high end boards ended up also went defective within a few months down the road. Buying a mobo will go by the convenience of the RMA centre location. The need for you to swap out the board if it is deemed faulty. Next is the features that you will need. Lastly the brand preferences.
2) Rams are expensive nowadays. And yes that is one of the reputable brands that is good and a dual channel rams.
3) Yes Thats the hard drive.
4) Yes a reputable brand for Memories.
5) Gpus. This is inconclusive. There are certain model that has better performance. Some model their for example r9 280x could be either gigabyte or sapphire that is better. It all boils down to their cooler used, their benchmarks, their overclocked out of the box speed and also the components used. Best is to search over the net and take a look. The thing is it is all the same chip used. A r9 280x is a r9 280x. It is only how the way the manufacturer which wants to implement it on a pcb board with their custom design and see what kind of performance they can push the chip up to.
6) Coolermaster was never good in terms of PSU. Only their high end range can be looked at. Anything GX series and below is rubbish PSU. Seasonic is the one of the best psu you can get out there. Other brands such as Superflower, FSP aurum series, Corsair RM series and above.
7 and 8) they are chassis and dvd drive respectively
Ark Law
Lol. Desktop GT540 (aka GT630) like dabian already, of course GT540M even more dabian :s13:
Modern gaming GPU is the main factor for graphical performance over CPU.
Oh, thanks so much for the info, where should i get the whole set from? Fuwell, Tradepac or PCTheme? How much discount will i most likely be able to get if i get the whole set? And is it even possible for them to fix it up for me?
shadow84
To get the most discount would be tradepac, but be FIRM with what you want. Prepare a backup list of parts in case certain parts OOS. But, if you are gonna ask the shop to help u fix up, TP isnt recommended.
Bring the parts to nigel's shop at #02-32 or ownself at home do. Pay him some reasonable fee for it bah.
Otherwise, get from pct. Wun get much discounts but they are trustable for the self build.
Thanks alot for the information! Much appreciated !
annoymous
And for dota 2 csgo, they are more cpu reliant, when i upgraded from 5770 to 7850 i still get the same fps but after i upgrade from fx4100 to 4570 the fps jump is huge.
Hi Roy, Jian and everyone else. I have googled about TradePac, and between TP and PC theme, it seems that there are quite a few thread saying that TP might give used products or wrong, to ensure i would need to know how to check. But as i am new to this, i have no idea how to tell. And it seems pc theme is more reliable and honest, but its more expensive.
Is what i said true? So which place should i even go to buy. If i had the knowledge i'd definitely go to TP
shadow84
You can start by gaining knowledge. Watch linustechtips and newegg diy guides... components are diff but methods are the same...
No one is borned with the knowledge of diy...
What i mean is i am afraid of being scammed when buying at TP as it seems they have a little bad feedback other than selling cheap things. Is it safer to go to PC Themes? Hmm ... i dont wanna get a used cpu or MB or something when i buy lol
