Help Needed on Parts!
Agung123
Hi HWZ,
I need some advice on whether my current tower & PSU will be able to fit my new upgraded parts.
Current Hardware:
• CPU: Intel i7-3770 3.4GHz 8MB LGA1155
• Mobo: ASUS P8Z77-V LX LGA1155
• Kingston Hyper-X Genesis 12800/1600 (2*4GB)
• WD Caviar Blue 1TB 3.5” 64MB SATA 3
• LG GH24NS90 24X SATA INT DVD Writer
• Coolermaster HAF 912 Advanced Edition
• Coolermaster GX 750W PSU Blue LED
Things that I want to upgrade:
• CPU: Intel i7-8700
• MoBo: ASUS TUF H370-PRO GAMING WIFI
• RAM: KLEVV PREFORMANCE SERIES 2666MHZ CL16 (8GB*2)
• GPU: MSI RTX 2070 8GB ARMOR
• SAMSUNG EVO 860 500GB M.2 SSD
• WD 2TB BLUE
Can kindly advise which parts can be integrated together & whether I need to get a new PSU and/or tower. Thanks guys! Appreciate it!:s22:
aaragore
Since its almost a complete overhaul, definitely change the psu, you dont want an old psu to fry your new parts, also casing is subjective but i would assume that u might want newer front ports (usb 3.1, usb c)
Koenig168
You can reuse the other parts for the CPU+MB+RAM upgrade.
It's up to you whether to change the PSU. Some feel that the PSU should be changed after a few years.
Same for the casing. It can be used though looks a bit dated. :)
SkyShroud
Everything is good.
PSU can be reused. 750w is enough.
HDD can be reused, duh.
Optical drive can be reused, duh.
Casing, base on specification, should have enough space.
-Synchronicity-
PSU if got warranty, use it. If not, get a new PSU.
Hdd - definitely
Optical drive - yes but depends on case if you choose to buy a new one(if it has dedicated space for it) anddo u actually use it?
Case - yes. Your own choice and preference if you want to change.
tsteo77
How to know which front ports of the casing is usb 3.0 ?
Agung123
Casing can reuse. PSU also can reuse. Can save jiu save bah!
Hdd - definitely
Everything is good.
Thanks for the advice guys! Since I'm upgrading most of the parts, I shall just do a complete overhaul and change the PSU & tower as well. Thanks again! :s12:
Aaagogo
seem like you just want to get a PSU and a prettier case haha,
MTBF of your PSU is >100,000 hours, that is >11 years of 24 hour usage.
so by manufacturers standard, your PSU would only be like 1/3-1/2 used life. Based on your CPU's launch in Q2'12 and now it's Q2'19, your PSU conservatively has been used for 3.5 years if 12 hours everyday and about 5 years if 16 hours everyday
your HAF 912 is a HUGE case that defaults support water cooling, and has enough space for 6HDD and 4SSD, seeing that you have 2 HDD and 1SSD, there is definitely plenty of space.
objectively there is no NEED to change for the upgrading of the mobo/CPU, subjectively whether there is a WANT to change is another story and that's a personal story.
