Help - Network Adapter not installed
Belial
Hi, need help here on the above issue. a few days ago, my pc suddenly cannot detect any network adapter, i couldn't install any network driver as my onboard network adapter gone missing. followed some advise found on the net and tried resetting my windows 10 but still same problem, suspect is my mb gone case liao. any one can advised if my suspicion is correct? currently on tight budget so would like more suggestions before spending money to buy new processor (ryzen 3200g) and mb (asus tuf b450m gaming).
my setup i7-4770 with Asus B85 Pro-gamer, 16gb kingston ram, gtx970, creative audigy fx, gamepro 650w.
Koenig168
From Device Manager -> Network adapters, you can see the NIC and its status.
wwenze
RIP mobo.
Find an old phone and connect WiFi to USB
Kiwi8
Deluxe Member
U can first buy either a USB-to-RJ45 adapter card or a PCIE-to-RJ45 adapter card, if u dun want to upgrade mobo yet.
hlots123
try turn off psu rocker switch, then press & hold pc power button for abt 20sec...
haoKRR
Go to that manufacturer page and download latest driver?
Perform reformat and try
Sent from HUAWEI VOG-L29 using GAGT
uncle_josh
run linux livecd.
if still cannot detect, most likely mobo up lorry
Sent from All you need is a leap of faith, the trust comes later. using GAGT
Belial
thanks all for the advice, upgraded to AMD in the end to put an end to the nightmare.
