[Help] New desktop will not start up
cuidado86
Left my desktop on overnight and the next morning desktop will not start up.
CPU Fan running
GPU fan running
Chassis Fan not running
No BIOS
No signal to monitor
Attempted to switch on this evening when i got home, managed to get into bios and then subsequently same problem as above
Attempt to rectify
Removed GPU
Cleared CMOS
Still the same problem
PC build
Asus Z87+
Intel i7 4770K
Cosair Vengeance 16gb
Intel 530 SSD
Seasonic 650W Modular
Please advise on what i should do.
bboyboss
Pp
CPU Fan running
GPU fan running
No BIOS
Attempt to rectify
Removed GPU
Cleared CMOS
PC build
Asus Z87+
Intel i7 4770K
Intel 530 SSD
Try to reconnect all the connections to the mobo but before that try booting with just one ram stick if that dosent work try the other. If your mobo has 2 bios's switch to the other. Your mobo has a debug led maybe you could see the code and refer to the mobo manual to see what's the error
huffie
have you check if the PSU fan is running as well? Previously had similar issue .. everything else running except PSU fan not running.
cuidado86
Ooo. Ok. I didn't know that will give that a try.
jtjt00
Possible the Seasonic 650W PSU causing the issue. If you google on Seasonic PSU issue, sure to find cases like yours.
