Help on 1.2k com
1208bran
Hi guys, I'm making a PC with a budget of 1.2k. If you could give some advice on this build I would be very grateful.
MSI Armor 1060 3GB -339
Kingston 2133MHZ 8GB valueram- 76
Techware F3 - 49
OCZ 240GB triton 150- 98
SEASONIC M12II-MODULAR 520W - 99
WESTERN.D 1TB BLUE 64MB SATA3 - 72
Windows 10 from carousell ~40
I5 6500 + Asrock H110M HDV(does this have a wifi card?) -392
Total 1165 (Prices gotten from PCT)
Some basic info:
I already have a monitor(1920 x 1080), mouse and keyboard
I plan on playing some AAA games like witcher
PC will be placed on the floor
Thanks in advance!
spiky0180
The motherboard you selected does not come with wifi.
If you want to lower the price further, can consider 1060 from zotac/palit, instead of the MSI one.
You can get a better PSU, FSP Aurum S 550W, at almost the same price as the Seasonic one.
MianBaoFren
Change gpu to zotac/palit for better budget.
Change psu. Fsp hexa 450w for 1060, 550w if u intend to whack higher tdp gpu.
Mobo has no wifi. Either get a pcie wifi card that costs 30+ from Taobao or buy the Asus b150 pro gaming aura (itx).
If u want to future proof to include m.2 ssds, get the mobos that support them. Otherwise, look into simple mobos like h110m will do. Check out the post by pugetsystems on the difference between mobos.
Finally, don't get everything off sls. Check online to buy stuff. If I am u I will delay my rig because next gen cpu is coming out.
Sent from A Cat Who Does Not Need A Reason To Post using GAGT
ssxdots
Looks pretty good actually.
I took a look at PCT price list and tried to upgrade the GPU but this is the best I can do without dropping the SSD.
MSI 1060 6GB - 369
Techware F3 - 49
FSP 450W 80+ HEXA PLUS - 58
MianBaoFren
MSI 1060 6GB - 369
Techware F3 - 49
That gpu is not an upgrade, it's a waste of money.
1208bran
MSI 1060 6GB - 369
Techware F3 - 49
I think I'll stick to the 3GB version, since theres not much diff..
Ok, Ill Search online, will get mobos to support m.2 ssds
And I'll wait for Kabylake since it's coming out in 2 weeks
