Hi I have just received my A levels results and I am currently deciding on what courses to apply for and am wondering whether the order of my choices will be important. My results are mediocre at 72.5 that seems to limits me to some courses only. My interests are mainly in FASS / social sciences / economics or Business courses. I am interested to put NTU business in one of my choices for NTU but since my results didn't meet the requirements there's high chance need to appeal.. Will the chances be very low? And since application process Is done via the order of choices, is it still viable to place NTU business as first choice and sociology as second choice?(which I have higher chances of getting into?) this is because I'm not sure how appealing may work.. If I put sociology as first choice and got in, can I still try appeal for business(if I placed it as second choice? Ie do you have to be rejected to appeal or you can try for other courses you stated too?) will I get higher chances for a secured place by putting sociology as first choice? Similarly should I still try for SMU business ?
Thanks in advance!
Thanks in advance!
