Help on building a gaming pc
Kira29125
Hi guys, im new to building PCs and i have never build one before, i want to built a entry gaming PC? Roughly budget about $300-500, not sure where to buy the stuffs as well as what to get.
Also is it possible to have a gaming PC that can be upgraded anytime, like buying new part and replacing the old one? As i may want to upgrade it and not to start from scratch again.
Please help me out thanks. Hope you guys are willing to help me out here. Thank you, also thank you for spending your time reading my post
A few games i would like to play are
Watchdogs
GTA V
Payday 2
Kira29125
Budget too low ~
Hw abt a gaming pc tt work tt range without counting the total of the monitor? :p im low on budget :x
Dont really have to able to tank the games i mentioned just if possible will be gd but cant its okay >_<
royfrosty
The minimum you should be looking at something like this
Asrock h81m dgs + Intel Pentium G3220 ~ $143
Crucial 8gb 1600mhz ~ $89
WD Blue 500gb ~ $62
Powercolor r7 250 1gb ~ $145
CM 311 + FSP Hexa 500w 80+ ~ $105
Samsung ODD ~ $21 (not needed but optional)
Dell s2230L 21.5inch eIPS Panel ~ $199
Total ~ $764.
Kira29125
WD Blue 500gb ~ $62
Total ~ $764.
Will look in to it and save more.. Money :x thanks
hengheng220
If you want to save, then have to compromise performance. If you want performance, you have to spend. Take note that Roy's build probably can support up to med settings 1080p on bf4
gaoxing84
Lol save more money is better than to buy a subpar pc and make you spend more later.
300-500 with monitor how can!
Kira29125
Guys, if my budget nw is 1-1.2k tts for the com, the monitor price is excluded, can i get a entry/ average gaming com?
shadow84
Hard to put in GTA5 on ur list as that may need a monster gpu. But with your budget, u should be able to play current games at 1080p with 60+/- fps or so, except for watchdog.
Kira29125
If manage to play watchdog and/or gta 5 wats the rough budget
shadow84
Right now, reviews are showing that watchdog needs 4Gb VRAM. So, you need r9 290 cards which are at least $600. If the game is optimised better, maybe cards with 3GB VRAM can play it smoother.
As for GTA5, u can go to the future and tell me bah, den i advise which card is good for it.
Kira29125
If i want to push the com till it at least can play watchdogs at its medium graphic... Can i have a rough budget pls?
