Help on DIY pc
danndelion
Hi guys, i am planning to build my own pc and i need recommendations. I have zero knowledge regarding this and appreciate if you guys would help. Games i am gonna play are simulation games like planet coaster jurassic world surviving mars frostpunk and maybe other mid range games. Want to play game without getting it too hot.
Budget if possible $1k +-100
CPU Ryzen 2600 + motherboard ??(recommendations)
GPU Power Color RX 580 8gb
Memory 16 or 8gb??
PSU 550w or 600w?
HDD seagate baraccuda 1tb
SDD Sandisk 240gb
Case ?? Heard it's important due to the airflow
Sorry if i am doing it wrong. Appreciate it much. :)
bobozhang137
Memory 16 or 8gb??
PSU 550w or 600w?
SDD Sandisk 240gb
lets say budget 1k. You dont have much choices regarding motherboard
Ryzen 2600 with B450m bazooka - 346
8gb ram - klevv 2666mhz - 75 sgd (16gb is 149)
240gb ssd wd green - 52 sgd
1tb HDD toshiba - 57 sgd
Thermaltake light power 550w - 58 sgd
Nexus M Tempered glass - 48
total = 710. leaves 290 for you GPU if budget is 1000. if 1.1k got 390 budget
a rx 580 is 298. so see what u wanna get lor
danndelion
Hi bro thank you for your suggestions 8gb ram is more than enough right?
shadow84
16gb would be ideal but with a budget, u have to make do with 8gb. Also if possible, do go for klevv bolt 3000mhz. Faster ram speeds up to 3000 helps ryzen even if u dun feel it.
danndelion
Hey thank you for your help. Will try to up my budget by a bit and get the 16gb.
