Help on GPU overclocking
givett
Hi all, sorry noob in overclocking, i max out everything for my MSI R9 270, power limit, core clock and memory clock, would it be ok or my gpu will boom?
allhomme
it won't boom.
it wont run. No one overclocks anything like that. google how to overclock gpu. there are tons of info on it.
Yureak
if its stable its ok as long as heat is under control
givett
Ok guess i will reset it back to original settings and until i see a need in OC then i will do it
royfrosty
Those who say it will boom then i would say it is not right.
270 is an underclocked card of the 270x. It has everything that 270x has. Just lack of 1 6pin connector. Everything else is the same.
270 to pull it to a 270x stock is just need to pull the bar to the max. No need to overvolt.
Memory clock just stay the same default will do.
imho...
not worth it to OC.
OC at best gives you extra 10% performance.
@ 30 FPS = 3FPS
@ 60 FPS = 6FPS
OCing will also lead to unstability and shorten the life of your GPU.
My 2 cents.
foo9883
You're lucky the sliders at max are only 1050/1500.
If it's like 1400/2000 confirm crash within 0.01 second upon game launch.
Yureak
imho...
not worth it to OC.
@ 30 FPS = 3FPS
@ 60 FPS = 6FPS
My 2 cents.
Chances are you wont keep your gpu beyond 5yrs long enough to experience the effects.
And secondly if you keep thermals under control it wont be an issue
Thirdly ocing on some cards like mine gives me a 40% boost
