help on installation path
morkutao
hi guys, is there a way to set installation path? for example steam, they'll usually prompt u where you want it to be installed.
but there are some files, they don't prompt u then it straight goes into my ssd.
jtjt00
You can if there is option during installation.
commach
Saved game files are located under your system drive user ID account, unless you intentionally moved or relocated it, it will go directly into your SSD which is also your system drive.
Not unique to steam, many games place saved game file in your user ID account too.
DJSnip3r
Under settings have option to create data storage location in diff disk. Then when you download, will prompt and ask you which drive to save in.
