Help on itx build budget 1.4k
acehigh
Hi guys. Looking to get a build from pc themes. Any suggestions would be appreciated as no matter how I do it it comes up to 1.6k.
Just cpu without windows and would like to get the GPU from them as well. Use case is gaming on 1080p monitor.
Sent from Samsung SM-N910G using GAGT
acehigh
Asus B150i PRO Gaming WIFI AURA ITX + I5 6500 = 495
Samsung 850 EVO M.2 250 Gig SSD = 139
WD Blue 64mb HDD 1 TB = 72
Corsair Vengeance ddr4 16gb = 179
FSP 550W 80+ HEXA PLUS PSU = 68
MSI RX 480 8GB GAMING X DDR5 = 459
Phanteks Enthoo Evolv ITX CASE = 129
Price from pc themes pricelist
lifeishard
Get a 126 ssd, change to 1060 3gb gpu, reduce ram to 8gb lor. Mobo can choose the msi h110i?
FlushX
You do know that apart from the Mobo+CPU bundle, the rest of the prices are at SRP right?
since you're looking for best bang for buck build, why don't consider buying parts online and building it yourself?
MianBaoFren
Encrypted11
At that budget you can get more than what you're picking currently. If you're afraid of hassle, try get the core of the machine built there at a shop. Pay up the assembly fee, ask that they leave the relevant power cables plugged and routed properly so she can drop in the remaining parts bought online easily.
(i.e. 1x GPU 6/8pin, SATA power + data)
Items below get online and stack discount coupons:
  • SSD, maybe HDD too
  • GPU
  • Maybe RAM
  • OS
Already quite straight forward and you can save some and yet meet the same objective since you want to reduce the hassle factor. RX480 8GB/1060 6GB can be obtained at comparable or similar prices (online) but the MSI model is not one of them. Mobo choice MSI H110i AC (with AC867 WiFi) will meet the same objective at a lower price point. Or alternatively, most buy online and you fix for your sis.. hassle factor will be gone.
