Help on motherboard
Genos.
Good day all!
I currently had this issue whereby I got myself some new stuff including a motherboard ASUS H310M-A
So what happened is that I reused my harddisk and the rest are new, I boot up the system but the OS refuse to start and restart the whole system instead. I read around the place and I tried everything I read up on such as disabling the secure boot, CSM run, switching off various settings in BIOs it still didn’t work and the system even lock out my keyboard when I tried to install new OS which I read that I need to reinstall OS to overwrite the settings. I have run out of ways to settle this and any help offered would be greatly appreciated!
Koenig168
Please try re-seating the RAM and GPU.
If that doesn't work, you can try with a minimum setup i.e. CPU+MB, SSD and single stick of RAM.
Ferolare
reinstall win7
but you need to do some hack since the latest gen chipset doesnt support win7
xonix
I tried but they lockout my entire keyboard how can I even do anything
FYI, you can inject the Intel 300 series USB drivers and get it to install but you will still encounter issues with the Intel graphics drivers. Just give it up and use Win10 lah...
Encrypted11
The cannonlake chipset H310 will be difficult to support Windows 7. It only has Windows 10 native drivers from Intel. Some of the integrated hubs might not work as expected.
If the board was using Z370 (Union Point Kabylake chipset) there are official windows 7 drivers from Intel available for the long term. So what Pusheen said :s34:
Encrypted11
That and even this works up to union point chipset (Z370/Z270/X299).
Whatever ____ point CNL-PCH is the legacy support has been killed.
Genos.
You need PS/2 keyboard to work.
Nope it didn’t work
Ya I was told to use Windows 10 by my supplier
Was told windows 7 doesn’t support my device so ya.
Ok:(
Understood.
Genos.
So what happen is that I’ll have windows 10 installed soon when I’m free to carry my cpu to the shop.
Hopefully it works
yusoffb01
do it yourself. dont pay someone for something free
download windows 10
https://www.microsoft.com/en-au/software-download/windows10
download rufus and use these settings
http://www.intowindows.com/create-uefi-bootable-usb-of-windows-10/
Try using your windows 7 product key. if cannot dont use any product key also can work, but cannot change desktop background
Genos.
