Help on replacement for armory crate rgb function
gatx105
Hi, i had previously used armory crate but found out its quite a bloatware.
Due to some unfortunate issue, I had done a full reinstall of windows 11. Now I am using remo0o for the fan curves, want to know if there are good rgb to tune it to light up in colors base on temperatures.
Thanks for reading and helping
KleoZy
SignalRGB (Universal Ecosystem)​
  • Overview: A highly polished, feature-rich universal software that unifies thousands of devices across different hardware brands (ASUS, MSI, Corsair, Razer, etc.) under a single dashboard.
  • Temperature Control: It features built-in system monitoring and layout configurations. While the core app is free, some advanced telemetry-driven monitoring features and custom cooling profiles sit behind their Pro tier.
  • Best For: Users who have a mix of hardware brands from different manufacturers and want a sleek, modern interface with out-of-the-box animated effects.
jinsatkilife
Does anyone know if can configure the led lights to turn on just before shutdown and then off when pc really shutdown?
I usually off all my led lights but need it as indicator when pc is powered down so that I can turn the power switch off
KleoZy
Turn on no.. before bios kicks in that is, all argb will be rainbow puke. As for turn off maybe, havent gone into that.. go explore apps like OpenRGB or SignalRGB
Vanyel
I tried both b4 but i think too complicated for my lvl
I just use the default mb + aircooler + casing + gpu softwares all together lol
User problem haha
uselessbum
The alternative is to have the rgb on while using but have it off on shutdown. You can do it via bios. For example, Asus's bios offers on/off options for the RGB for both when the PC is use and on shutdown. In asus bios, it's under onboard devices configuration, not sure about other brands but they should have something similar as well.
86technie
@TS which ASUS motherboard are you using?
Most ASUS motherboard should have a setting for you to turn off the RGB when you shutdown the PC.
Armoury crate I agree is a rubbbish software, I don't installed it as it can cause issues
especially conflicting with other software like iCue etc.
