feixiang1106
- Oct 20, 2007
hi, Guys
currently I plugged one Powercolor 6850 PCS on my rig, it seems to be a bottleneck of my rig, the temperature can easily heat up to 90+, after i clean the fan and lay more thermalpaste onto the GPU, the temperature dropped to around 80 degree when I play Diablo 3 and Civilisation V. but the noise is horrible, my wife complains a lot everyday. plan to get a quiet and powerful card to play games like COD and do some engineering works like Ansys and 3D model building (no rendering), can you guys recommend some stuff within the budget of SGD 700 and can fit with my CM 690 casing.
I am quite interested to get the Gigabyte GTX 770 OC 4GB version, so that i can do the dual monitor setting, my wife can watch her movie and i can play games in silent mode....
thanks advance for your help.
