Help! PC can't turn on after building
flyerfox
Hey guys, raelly need your help. I completed assembling my PC and when it first turned on it said sth like CPU or Ram (can't remember) memory has changed. Press F1.. press F2. I didn't have a keyboard at that time, so I turned off the PC.
Now when I wanna turn it on (I didn't change anything), it doesn't turn on. Anyone can help me pls? I just wanna fix it and go to sleep..
flyerfox
I realise that I have no post-startup beep although the pc starts up fine and I can enter bios. Is there a problem or way to fix it? I have installed the motherboard speakers already
Alternative X
Don't worry, your rig is perfectly fine. I do not think computers nowadays have this startup beep anyway.
flyerfox
Oh, ok thanks! But if no beep sound.. next time how would I know what is the error? Or nowadays they don't give beep error codes ah?
coyote
some motherboard has beep sound disabled in bios by default & it also mean you can turn it back on in those that has this option. Check it.
