[help] PC hang
icygolem
[help] PC graphics freezed, BSOD.
PC keep graphics freeze when i play Dota 2.
After hang i can't do anything but to hard boot.
Specs as per right side.
icygolem
Downloaded open hardware monitor. Results are shown below.
Graphics card at 55C value and 59C Max while playing games.
Could it be my SSD dying?
Please help!
Sensors
+- ASRock Z77 Pro3 (/mainboard)
| +- Nuvoton NCT6776F (/lpc/nct6776f)
| | +- CPU VCore : 1.064 0.824 1.088 (/lpc/nct6776f/voltage/0)
| | +- Voltage #2 : 1.856 1.832 1.872 (/lpc/nct6776f/voltage/1)
| | +- AVCC : 3.28 3.264 3.28 (/lpc/nct6776f/voltage/2)
| | +- 3VCC : 3.264 3.248 3.28 (/lpc/nct6776f/voltage/3)
| | +- Voltage #5 : 0.32 0.08 0.44 (/lpc/nct6776f/voltage/4)
| | +- Voltage #6 : 1.696 1.688 1.696 (/lpc/nct6776f/voltage/5)
| | +- Voltage #7 : 0.816 0.808 0.832 (/lpc/nct6776f/voltage/6)
| | +- 3VSB : 3.44 3.44 3.44 (/lpc/nct6776f/voltage/7)
| | +- Temperature #1 : 49 45.5 53.5 (/lpc/nct6776f/temperature/1)
| | +- Temperature #2 : 40 39 40.5 (/lpc/nct6776f/temperature/2)
| | +- Temperature #3 : 40 39 41 (/lpc/nct6776f/temperature/3)
| | +- Fan #2 : 2454 2360 2631 (/lpc/nct6776f/fan/1)
| | +- Fan #3 : 1271 1253 1283 (/lpc/nct6776f/fan/2)
| | +- Fan Control #1 : 100 100 100 (/lpc/nct6776f/control/0)
| | +- Fan Control #2 : 100 100 100 (/lpc/nct6776f/control/1)
| | +- Fan Control #3 : 100 100 100 (/lpc/nct6776f/control/2)
+- Intel Core i5-3550 (/intelcpu/0)
| +- Bus Speed : 100.004 100.004 100.011 (/intelcpu/0/clock/0)
| +- CPU Core #1 : 3500.14 1600.06 3700.15 (/intelcpu/0/clock/1)
| +- CPU Core #2 : 1600.06 1600.06 3600.14 (/intelcpu/0/clock/2)
| +- CPU Core #3 : 1600.06 1600.06 3700.15 (/intelcpu/0/clock/3)
| +- CPU Core #4 : 1600.06 1600.06 3700.15 (/intelcpu/0/clock/4)
| +- CPU Core #1 : 59 48 68 (/intelcpu/0/temperature/0)
| +- CPU Core #2 : 58 48 69 (/intelcpu/0/temperature/1)
| +- CPU Core #3 : 56 46 68 (/intelcpu/0/temperature/2)
| +- CPU Core #4 : 55 45 66 (/intelcpu/0/temperature/3)
| +- CPU Package : 59 50 69 (/intelcpu/0/temperature/4)
| +- CPU Total : 27.6923 15.7692 71.5385 (/intelcpu/0/load/0)
| +- CPU Core #1 : 36.9231 4.76191 100 (/intelcpu/0/load/1)
| +- CPU Core #2 : 35.3846 0 83.0769 (/intelcpu/0/load/2)
| +- CPU Core #3 : 16.9231 0 87.6923 (/intelcpu/0/load/3)
| +- CPU Core #4 : 21.5385 0 64.6154 (/intelcpu/0/load/4)
| +- CPU Package : 18.7348 12.4113 34.8619 (/intelcpu/0/power/0)
| +- CPU Cores : 12.6299 6.42413 28.1571 (/intelcpu/0/power/1)
| +- CPU Graphics : 0 0 0 (/intelcpu/0/power/2)
+- Generic Memory (/ram)
| +- Memory : 47.4129 45.9978 48.589 (/ram/load/0)
| +- Used Memory : 3.74443 3.63268 3.83731 (/ram/data/0)
| +- Available Memory : 4.15306 4.06018 4.26482 (/ram/data/1)
+- NVIDIA GeForce GTX 670 (/nvidiagpu/0)
| +- GPU Core : 966.774 0 1097.42 (/nvidiagpu/0/clock/0)
| +- GPU Memory : 3054.83 324 3054.83 (/nvidiagpu/0/clock/1)
| +- GPU Shader : 1933.55 0 2194.84 (/nvidiagpu/0/clock/2)
| +- GPU Core : 55 43 59 (/nvidiagpu/0/temperature/0)
| +- GPU Core : 7 0 81 (/nvidiagpu/0/load/0)
| +- GPU Memory Controller : 3 0 52 (/nvidiagpu/0/load/1)
| +- GPU Video Engine : 0 0 0 (/nvidiagpu/0/load/2)
| +- GPU Memory : 35.9186 29.0552 37.1428 (/nvidiagpu/0/load/3)
| +- GPU : 1290 990 1350 (/nvidiagpu/0/fan/0)
| +- GPU Fan : 42 32 43 (/nvidiagpu/0/control/0)
+- M4-CT128M4SSD2 (/hdd/0)
| +- Used Space : 87.9424 87.941 87.9425 (/hdd/0/load/0)
| +- Remaining Life : 99 99 99 (/hdd/0/level/0)
+- Hitachi HDS721010DLE630 (/hdd/1)
| +- Temperature : 36 35 36 (/hdd/1/temperature/0)
| +- Used Space : 99.9196 99.9196 99.9196 (/hdd/1/load/0)
jtjt00
so does that mean if i should find ways to bring it down?
any advice?
1. minor cleaning of the GPU fan
2. more advanced is to remove the HSF, clean of the old thermal paste and reapply new.
Do take note risk is involved and worse end up with a brick card.
Klass_Computers
This is good advice. Most likely the hanging is caused by overheating. Try cleaning off any dust from your fans or heatsinks and see if the issue persists.
icygolem
Hi all
After the graphic freeze, I tried to do some read and write test for my SSD.
Then i got a BSOD amidst of it.
After getting BSOD, I tried to take out one of my 4gb RAM.
and after taking out the 1x4gb RAM, seems like no more graphic freeze and no BSOD.
Tried running memtest86 on both RAM 1 by 1. Ran 1 test each on both and both passed with no error. (maybe I should run more test?)
Right now I insert back the other RAM, so far no graphic is freezing and no BSOD is happening thus far.
Get anyone give me some advice?
vironix
seems like ur rams needed a re-seat.
happens as com get old...my rams also fickle one. i try not to touch them too much
suavegamer30
Probably the golden contacts of the RAMs are dusty.
Hi all
