[Help] PC suddenly no display anymore
fishyy
Hello all,
I was playing CSGO, then all of sudden, black screen, no more display, monitor says there's no signal coming from the computer. PC is still on though.
What I've tried:
Changed output from GPU to directly from the motherboard using HDMI.
Tried swapping rams; using single stick
Connect the monitor to display from other PC, this concludes monitor is fine, the mobo is the problem here.
Unable to find CMOS battery to reset, I think there's a switch, but I didn't do it.
There's a solid orange LED from the mobo somewhere.
So... what could be the problem here?
Please help :(
EDIT:
MOBO = GA-h170-wifi - itx mobo
Monitor = U2414h
Koenig168
You can reset BIOS by removing the CMOS battery and replace after a few minutes.
The CMOS battery is the round shiny thing. :D
fishyy
I know that. but the mobo seems like no have it leh. or maybe i missed it.
Here's the pic
