Help please on display
  • Need someone to talk to?
kimmeng
Recently I have issue with my display (unable to detect HDMI signal / no display out) which I have just RMA back a Palit gtx 1060 3GB GPU.
After RMA 6 weeks it came back and ran through a stress test at convergent again before I took it back. I installed back to my CPU, initially it works fine. However, after a while the whole monitor will auto black out and pop out the display error msg again (unable to detect HDMI signal / no display out). I try to change out the HDMI cable and try it again, fault still persist.
Guys on IT expertise, please advise what are the possible components that keep causing the whole screen display to black out intermittently. I am using ASUS B250F STRIX GAMING mobo. Or the issue lies on the motherboard?
Possible components
1 - After RMA GPU still no good?
2 - MOBO no good?
3 - HDMI cable replaced.
Koenig168
You can try testing with the onboard HDMI. If it works fine, then problem is with GPU.
kimmeng
I checked the window log, the error log showed this. How do I fix this.
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
{D63B10C5-BB46-4990-A94F-E40B9D520160}
and APPID
{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}
to the user DESKTOP-I5FQD61\Kim SID (S-1-5-21-1176544354-1333462346-2716383392-1001) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
