HELP! Problem booting thru USB using RUFUS
feitz
Hi,
I have a problem trying to boot to FreeDOS using RUFUS application to create a bootable USB.
USB used: 16GB Toshiba USB2.0 thumddrive
SW used: RUFUS. set to "MBR partition for BIOS or UEFI computer", FAT32, Create a bootable disk using FreeDOS.
In BIOS, the thumbdrive is recognised as UEFI device and i set it to first BOOT. no second boot device.
After saving the BIOS setting and restart. Thumbdrive did not boot and i was shown the BIOS screen again...
Anyone has any experience using RUFUS?
Thanks!
Background: I need to boot to DOS using bootable USB to apply wdidle3 on my scorpio blue HDD drive.... excessive load cycle problem.
feitz
the problem with my BIOS seems to be that it supports UEFI mode only....
yusoffb01
I dont think freedos supports uefi? so try to revert back to legacy bios
feitz
i wish i can change to legacy bios but my bios seem to run only uefi...
feitz
problem resolved. managed to boot to fedora live USB and run idle3-tools (linux equivalent to wdidle3). Case closed! :)
