Help! problem with ASRock mobo
Beepok
Ever since I switched from a wireless keyboard to wired keyboard, my computer boots itself whenever a key is pressed. How to disable this? I cant find anything in bios settings. Fast boot is off. Running windows 10
localITguy
Suspended
disable the fellowing under, Advance>ACPI Configuration
USB Keyboard power on
USB Mouse Power on
PS2 Keyboard/Mouse power on
gld998
Beepok ar beepok... Mr Gian Png is in the house!! :s13::s13::s13:
Beepok
USB Mouse Power on
Thank u bro. But then they are already disabled Yet it auto on
shadow84
Aiya, help him a bit, if not, he cant type his address into foodpanda website and collect food when his com keeps rebooting.
Beepok
only way is to off power switch whenever I shut down...if not com will auto startup and run till next morning, when mouse or keyboard is touched
localITguy
Suspended
your kb got light is because of the 5v stanndby power
please go and set the jumper on your mbo PS2_USB_PWR1
If ur mbo does not have the fellowing jumper, please set [Deep SX] to [Enable] in BIOS.
Or set [On/Off Play] to [Disabled] in BIOS.
as for why your mouse still turns on the PC, i dunno.
by right it should be turned off after you disable it in bios
