Help! PSU problem?
udonc1841
Recently experienced PC power off and on again several times randomly. Tot is power socket problem but the socket beside connecting to my router have no issue and tried swapping sockets but issue still persist.
Also no OC, changes in hardware or software recently, so by deduction my guess is PSU prob. Anyway i can check / troubleshoot?
The model is Corsair RM750 btw if that helps.
yusoffb01
Try the psu on a friend's PC
Random shutdown can be due to PSU, ram, Faulty graphics, motherboard
yusoffb01
Thanks, but the link is more for when you cant power on right?
my prob is like 'power trip' at random times, like yesterday it 'trip' twice in 15 min but then no prob until today 'trip' again.
If have long warranty then let them test
lcheowl
during randomly shut down and the casing fan is still running, just remove all your card and use an eraser to rub the gold connector.
feedback if it still having problem.
katata
Hey, just want to give my 2 cents. My parent's computer that I built for them 5 months ago recently also started having this issue. Random restarts. Occurs completely randomly throughout the day and on any application. e.g. Surfing web, typing in excel or just idling. No blue screen, error messages or anything. Just a sudden power off and automatic power on.
Wah this problem was so hard to resolve. I know that generally its either A) PSU or B) Motherboard. I tried resetting bios, scanning for malware, running a hdd check and doing a memtest for ram to eliminate possible candidates. My worst fear was that it would be motherboard failure. Very ma fan.
In the end, I took a spare power supply to replace it. And everything is working fine now. I replaced the seasonic S12G 450w powersupply with a 5 year old OCZ ModXStream 620w powersupply and the random restarts have stopped thus far. It has been about a week already, still smooth sailing.
My recommendation would be go through the standard checks to eliminate culprits and then try to get someone to lend you a working power supply to check. If not, then I think its motherboard lo.
