[Help]Recommend a GPU
JapVodka
Please help! I'm quite clueless in tech gadgets.
Current 2.5yrs old RIG:
i5 760 2.8ghz quad core
Gigabyte P55A-UD3 motherboard
12gb ram
WD 640gb sata hdd
Seasonic M12-ll 620W PSU
My trusty GPU, MSI GTX460 hawk 1gb twin frozr II had one of it's wing(Fan) clipped):
Can you gurus please recommend me a gpu to replace.
Would hope the budget to be within $200-350(preferable under $300)
Also would like to know if [MSI N650GTX-Ti Twin Frozr III OC BE Graphics Card] = [MSI N650GTX-Ti 1GB/OC Hawk]?
If it is, then is this a good replacement for my old GTX460 and is it priced under $300?
Lastly, is there a big difference between [MSI GEFORCE GTX650 TI HAWK 1GB GDDR5] vs [MSI GEFORCE N560GTX 1GB GDDR5 TWIN FROZR II OC]?
Oh and it's for games like Starcraft 2 Battlefield 4 & FinalfantasyXIV. So with your recommendations, would I be able to play on ultra high graphic setting or not beyond medium setting?
Thanks in advance and have a pleasant day ahead!
xing221
Get the HD 7850, it's more worth the money than a GTX 650 ti boost, and it overclocks well too.
Oh, since next gen games are more catered towards AMD's Graphics core next (as next gen consoles are using AMD architecture), the HD 7850 will perform better than Nvdia's cards in the future.
Oh if you decide to get it, get the 2gb version.
At fuwell, sapphire hd 7850 2gb oc edition retails at $258, equivalent GTX 650ti twin frozr boost from MSI retails around $283
royfrosty
Prices from Fuwell
Palit Gtx 660 OC 2gb $289
Sapphire HD7850 2gb $259
Tradepac
Powercolor 7850 PCS+ 2gb $249
Powercolor 7870 Myst 2gb $290
Palit Gtx760 Jetstream 2gb $349
twasken
most bang for buck at this price/performance range is the 7870 Myst with your budget. Good card but downside is that it runs quite hot in 80+ deg range for the likes of BF3 and bioshock.
xing221
Enjoy your new card, recommend you to OC it for better performance :D
