(HELP) recommend me a psu
Wishdom
Yes...........
btw, I am using the same 550w older Golden King version, still going strong.
i see. Ive heard good things about superflower.
just wondering, is there a huge difference between gold and platinum? because the seasonic has 7 years warranty while superflower only has 5; averaged out its almost the same..
Wishdom
usd
local dont over oversea product
if ur buget low 100 get superflower
Hi, i was hoping to get a good one that will lasts.
I am looking at seasonic because it has 7 years warranty over the 5 years warranty given by superflower. the pricing seems similar when averaged out.
jtjt00
Since both average out on price/warranty, then distro location is next to come into picture. Tech Dynamics for SuperFlower is at Chai Chee Lane, while Corbell for Seasonic at AMK.
Wishdom
I live in yew tee, so ang mo kio seems closer :) i guess seasonic it shall be.
thank you. will i be able to get a better price than lazada? or is 212 good?
jtjt00
thank you guys.
anybody knows where to get SeaSonic X Series X650 Gold cheaply online?
i know lazada has them for $212. is it a good offer?
Unless you got coupon to bring down price below $195, else you can get from Fuwell/PC Themes at $195.
wwenze
If you no budget, buy bronze also can. And instead if satki brand buy cheaper model also can.
Wishdom
what's the main difference between gold and bronze? i know the price difference is pretty big lol.
wwenze
is it worth the difference for electricity bills?
lets say i switch the computer on everyday.
Efficiency of 85% vs 90%
Means, if you normally pay $90 per year for your computer with a Bronze PSU, you will pay $85 per year with a Gold PSU
lalalalalala
not much diff, as long as it's 80+ rated means the components are of certain standard already. getting from a reputable brand like fsp, seasonic or superflower is more important
the importance of the efficiency or ripple is only significant during overclocking as people want to push their chip to the limit and any voltage spike can kill their chip. hence need to get really good and stable power supply
jtjt00
Beside efficiency/cost, Gold and Platnium models used better quality component which emit little or no heat at low to mid wattage. So the fan does not need to run at all time until preset wattage/temperature reached.
lalalalalala
Wishdom
thanks for all the help guys.
i think ill get Seasonic S12II-520 80+Bronze at $89 from lazada.
