[HELP] Recommend parts for DIY setup
onimenokyo
Hi,
My 5-year old DIY PC died on me.Was told to get a total new setup by my peers.Not really much of a PC enthusiast so would like the experts here to recommend me a setup with a budget of around max 1.5k with some salvage parts.
These are the stuffs I "deciphered" from my receipt which I hoped can be salvaged
1. Asus Monitor 24" 2. Logitech Mouse & Keyboard 3. Transcend SSD 250gb 4. Seasonic PSU 750 Watts (should i buy a new one?) 5. Fractal Design R4 Casing (should i buy a new one?)
The purpose would be mainly for gaming and a little simple Photoshop :D
Thanks!!
singupingu
CASE: Phanteks Eclipse P400 TG ($139)
MOBO+CPU: Gigabyte AB350 Gaming 3 + AMD Ryzen 5 1600 ($513)
RAM: Corsair Vengeance LPX 2666MHz 2x8GB ($199)
PSU: Superflower Leadex Silver 650W ($139)
SSD: *reuse*
HDD: WD Blue 1TB ($72)
GPU: Zotac GTX 1070 Mini + backplate ($500 after $100 coupon from Qoo10 sold by vii gamer)
OS: Windows 10 Home (<$20 via carousell)
TOTAL: $1582
Prices quoted from PC theme or otherwise stated.
If you can bargain, go tradepac @ level 5 and I am sure you can squeeze this specs (minus gpu and os) into a price that fit your 1.5k budget.
I'm focusing quite a bit on aesthetic. If you can forgo aesthetic bling, then ya, 1.5k is no issue fitting in at all.
Sent from Overpowered Phone Mark III using GAGT
Providence
Hi,
Thanks!!
Your PSU is definitely more than enough for any rig. :D
onimenokyo
SSD: *reuse*
TOTAL: $1582
Hi thanks for the recommendation! May i just know how to get that $100 coupon for that item? Never bought items from Qoo10 before...
And i suppose I get a new PSU since its 5 year old dont want unnecessary trouble :D
stylechap
You're in luck.
The $100 coupon is available for grab from now till 30april.
So you have till 30th to decide and make your order.
You could save a bit more by purchasing their $100 giftcards at $97. BUT THIS IS AT YOUR OWN RISK.
They might review your giftcard purchase before processing and its usually only done during office hours. Which means theres a chance you'll get your giftcards when the $100 coupon expires.
onimenokyo
Thanks! Yes i saw that Qoo10 $100 cart coupon. Looks like a really good deal...almost certain of getting it :)
shadow84
If u have not gotten ur case and hdd yet, u can consider getting case from techdeals at $140-$20 and maybe a 2 dor 3tb hdd above $100. There is a $20 off $100 coupon as well.
