Help recommendation for gaming rig
loco_artist
Hi, I am intending to build up a gaming pc that can play games like Battlefield 4..etc. in high-max settings. I have no idea on anything about computer parts but I will have a friend who knows how to build a pc to head down to Sim Lim with me.
My budget is around $1200-$1500, what parts do you guys recommend I should be getting. Best if the budget can include monitor. And lastly, does getting the shop people to build up have any charges? Or just ask my friend do better?
JesusLovesUs
I did this for my friend, you can use for reference.
Tradepac
452$ - Asus H97-Pro + i5-4690
100$ - WD 1 TB Black
113$ - Cruciam MX100 128GB / 163$ 256GB
114$ - Corsair Vengence 1600MHz
95$ - Xigmatek Assasin ATX GAM Case
109$ - FSP Aurum S 600W 80+ Gold
21$ - Samsung 24x DVDRW SATA OEM
499$ - Powercolor R9 290 PCS+
120$ - Microsoft Windows 7 Home Premium 64 Bit(fuwell)
Total(No Monitor) - 1623
Total(Glossy Monitor) - 1832
Fuwell
476$ - Asus H97-Pro + i5-4690
101$ - WD 1 TB Black
115$ - Cruciam MX100 128GB
115$ - Corsair Vengence 1600MHz
89$ - Corsair Carbide Series SPEC-02/03 Mid Tower
149$ - Seasonic G-Series 650W Modular 80+ Gold
24$ - Samsung 24x DVDRW SATA OEM
428$ - Asus R9 290 4GB GDDR5
Total(No Monitor) - 1521
Total(Glossy Monitor) - 1730
Best Bargain
480$ - Asus H97-Pro + i5-4690
79$ - ENERMAX Ostrog USB3.0 + SSD
109$ - SUPERFLOWER HX600 GOLD / FSP Aurum S 600W 80+ Gold
22$ - Samsung 24x DVDRW SATA OEM
Total(No Monitor) - 1569
Total(Glossy Monitor) - 1778
Dell s2340L ($209) - hdmi, dvi, glossy, no height adjustment, no vesa mounts
If you buy everything form same shop, they can build for you. But if you ask for discount, that might be another matter.
I think you can take away the SSD/HDD(suggested for my friend) to reduce the cost as required.
shadow84
U shld stop putting in u2312hm... eol le.
Also, for comparison, u shd try to use same parts.
royfrosty
1.5k
ASRock B85 Killer + i5-4460 ~ $355
Crucial 8gb 1600mhz Value Ram ~ $95
WD Blue 1tb ~ $71
Plextor m6s 128gb ~ $119 (5 years warranty over standard 2 or 3 years)
Zotac GTX760 2gb ~ $338
Superflower HX500 500w 80+ Gold Semi Modular PSU ~ $88
Sharkoon BD28 ~ $77
Samsung DVD Drive ~ $21
Windows 7 Home Premium 64bit OEM ~ $110
Dell S2340L 23inch eIPS Panel ~ $219
Total ~ $1493. Buy at tradepac. DIY
