Help regarding GPU fan
kangbikeco
I have an asus Gtx 680 with one broken fan, anyone here knows where I can get the 95mm 4pin replacement?
MoneyFace =p
Get a 92mm fan, cut out its frame and stuck it into the emptied spoilt fan slot and make do with it lor.
Koenig168
Yeah i know quite expensive... maybe can try moneyface method if you dare to try.. haha
Sent from Asus ASUS_T00P using GAGT
Actually, I threw away one of these GPU fans one or two months back. Ripped it from the stock GTX 690 cooler when I wanted to take out one of the vapour chamber heatsinks. It was a very good fan, being able to cool a GTX 690 but I had no use for it.
kangbikeco
Thanks guys, I've already ordered from aliexpress but I kinda need it asap. Any of you guys knows a specific shops from SLS that sells that?
Krabs.
80mm fan more common
you can cable tie it temporarily , should be no problem in the meantime if u don't stress the card too much heavy load
