[Help] Rig for Gaming
deadguy
Need help on choosing parts for gaming rig. Budget 1.5k - 1.6k. Need OS (Windows 8.1) and monitor. Don't need SSD and ODD. Casing, Ill prefer the Corsair 240 unless budget not permitted and GPU will be GTX970.
Games will be mainly ACU, NFS, GTA V, Middle-Earth: Shadow of Modor, The Sims 4.
This is my "list" from reading this forum.
Mobo + CPU: ??? + i5-4460
RAM: ???
GPU: GTX 970 (Palit Jetstream/MSI Armor/ZOTAC)
HDD: Western Digital Blue 1TB (Others?)
PSU: Cooler Master V550 Semi-Modular (Others?)
Case: Corsair 240 AIRFLOW
OS: WINDOWS 8.1
Monitor: ???
Thanks
deadguy
Nope. Need SSD? Cause I don't play online gaming that much only leisure gaming.
royfrosty
With that budget, better to have an SSD.
It is not just games that you will benefit. There are many benefits towards it.
1. Game loading reduce drastically. Such as Civilization, Diablo 3.... And the list goes on. It helps also for those move to checkpoints and the game does a save for you. Its smooth in transitions over a choppy HDD. Most of the games mentioned will benefit from smooth transition thru checkpoints.
2. Fast boot up of OS and other applications.
3. Overall stability and responsive of the OS.
1.6k with monitor
ASRock H81m hds + i5-4460 ~ $299
Crucial 8gb 1600mhz Value Ram ~ $96
WD Blue 1tb ~ $68
Crucial mx100 256gb ~ $148
Zotac GTX970 4gb Dual Fan + Superflower HX600 600w 80+ Gold Semi Modular PSU ~ $547
Corsair 240 ~ $129
Windows 8.1 OEM ~ $120
Dell S2340L 23inch eIPS Panel ~ $198
Total ~ $1605. Buy at tradepac. DIY
