Help Roborock G10s
tipsy
Through a fren, bought a roborock G10s during last year 1111 from taobao, havent been able to get it working... Have already downloaded xiaomi and roborock china version app also unable to connect to the device. The message reflected is "The device is not certified in the current country or region and cannot provide online services for the time being. If you have any questions, please contact the dealer"
Any guru can help?
wongminmin
roborock is region locked.
u can try this...
Step zero: make sure your phone has root Step two: get a China VPN, I used flyVPN from google play store and bought one month subscription, it’s not free Step three: install vpn hotspot from github Step four: turn on the vpn, make sure it’s global mode, not app mode Step five: share your vpn via hotspot in the vpn hotspot app Step six: profit, connect your bot to the hotspot you just created, and you will notice the region lock is gone, and you can control it with any phone, it doesn’t have to be on China VPN, and the timezone is also set to your local timezone as well. Remote monitoring and videos are all working but a bit slow since it’s tunnel to China now
