ItsmeagainhK
- Feb 23, 2008
Hi everyone
My previous Plantronic wireless headset just broke into 2 so I went to get a Logitech G430 as the replacement. This Logitech model is not a wireless one.
As I usually have speakers on in the day and used headset only at night or gaming with skype on going behind. I have already checked that the headset and the current speakers I have are working perfectly fine. The problem is that I can't get both to work consecutively. I have to disable one , enable another before I can use it.
For example: I'm using speakers now and wished to change to headset , I have to disable my speakers and enable my Headset.
I understand that I can get both to work together by setting Stereo Mix as the default device , " check the Listen to this device " and choose my headset for the option "Playback through this device"
However , The quality of the music that comes out from the headset/Speaker with the settings in place are reduced and with noises. Only when i enable one and disable the other will I get back the original quality.
Is there any thing I can do to ensure that I do not have to keep enabling/disabling each option and still enjoy the good original quality ?
Thank you for any help.
