HELP! Transfer Data from Note 2 to Note 3 (No Frills method)
Paranoid
Hi Need Advise
Got a Note3 and wish to do a transfer from Note2.
Apps,Emails, Contacts, SMSes, Whatapps are the priority
The rest like photos are not so important
I tried Titanium Pro and installed it (Paid) but when I open it, it prompt me to "root" my device.
Any other way?
Thanks!
Jurong640
Hi Need Advise
Any other way?
Thanks!
the manual way.
Contacts and smses can be backuped using samsung account. Go settings>Accounts>Samsung Account>Backup
For whatsapp
Go whatsapp>Settings>Chat Settings>Backup conversations.
Than in your my files folder, copy the whole whatsapp folder to your microsd card, put the microsd into note 3, re install whatsapp from playstore
upon installing, they will advise you to restore messages, click ok
apps you have to use
titanium backup but u need to root first.
You could let the apps reinstall if you backup your apps on playstore.
Go Settings>Backup and restore
Paranoid
the manual way.
For whatsapp
GREAT INFORMATION!
Thank you Sir! :s12:
kambing_chua
Hi Need Advise
Any other way?
Thanks!
u can also use (super backup) from play store.... it backup apps, sms, contact, contact list, celander n bookmark.....
after u backup from note 2, copy all the folder into SD card... put ur SD card into note 3... and just restore it.....
progene
Use google contact... Easy.
All contact always in google.
