tc4237
- Jul 12, 2010
Background: using an old z77 extreme 4 with 16GB ram and 520w PSU. GPU is 1070ti mini
It's been working fine. once in a while, there are occasional ram issues but a re-seating of ram and some restarts will solve it.
The problem today: GPU starts producing artifacts on start up and after going into windows. it's un-usable. did restart and then it shows the same thing and code 43 in device manager. device manager detects GPU but shows an exclamation triangle icon. CPU-Z doesn't detect GPU.
tried:
- re-install drivers, both old and new (it shows installed completed, but windows says need to force install drivers again)
- changing GPU slots
- using my old GT 660 graphics card, it also has artifacts
- different ports on GPU. artifacts on both HDMI and DVI ports
- reinstalling bios (2013 version, which is also the latest)
all didn't solve the issue
now I'm using it without GPU, directly connected to motherboard DVI slot. but I can't play games with this setup. and ideas?
tried:
